ABSModule bolt 9203936 source McMaster car documented here
Has thanked: 1614 times
Been thanked: 4078 times
abscate wrote:Joe..would you mind posting part numbers for the SS bolts to this thread please
here's what I ordered from McMaster Carr
92290A188 Metric 316 Stainless Steel Socket Head Cap Screw, M4 Thread, 50mm Length, .7mm Pitch, packs of 10
92153A418 Metric Type 316 Stainless Steel Split Lock Washer, M4 Screw Size, 7.6mm OD, 0.8mm min Thick, packs of 100
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Exact same issue for me, three (3) out of four (4) E5 bolts came off, but the last bolt, bottom near the firewall was stripped.
I have tried both E5 and 5/32" sockets to no avail.
I was about to give up, or to try dremel tool (a PITA due to awkward angle).
Relax, I looked at the bolt head, believe it or not the Torx area is tapered with the outer part of the head being E5 but the inner part near the "washer" portion is E6. Out of desperation, I tried E6 socket and it worked!!!
So guys, use E6 socket as you wish!
Bump
Part number for screw is 9203936
The 316 stainless steel screws. With internal hex heads are back kordered but I have a bunch coming in aboutb4vweeks
Pm me if you need them
Feb 2022
Shipped out three more sets of ABS screws this week.
Just pm me and I drop them in the mail
Price,,,pay it forward.
Courtesy of Grayson Ellie
