99 v70xc rough running ,code for cyl. 4 misfire
was driving on interstate and car started running rough and shaking some, poor power. code for cyl. 4 misfire. parked in garage and left it to travel for the holidays. idling was very rough, and low power so I'm betting BAD COIL on cyl. 4. i have volvo plugs with 20K on them. I'll keep you posted.
99 V70XC 158K
95 850glt 188K
95 850glt 188K
- Year and Model: Many Volvos
- Been thanked: 76 times
Swap the coil to another cylinder and see if the misfire follows the coil. If so you found your problem for sure.
well I switched 3 and 4, and code stayed with 4. the coil for 3 had the boot part of the coil come off by staying in the hole, but I was able to get it on 4 OK, and the code stayed on 4. cleared it twice , plug looked oily, and even with new coil I had, code stayed with 4. p304
99 V70XC 158K
95 850glt 188K
95 850glt 188K
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sorry to read.
well a good local machine shop will rebuild Volvo heads! I am going to buy head gasket kit and wonder, are all 12 of head bolts the same size?(the chassiss number at end of my VIN are 594432)
99 V70XC 158K
95 850glt 188K
95 850glt 188K
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
I've only ever seen one size.
5 others that came and went
- rspi
Contact rspi..
Did a valve have a hole in it?
- 1724 Views
Last post by petermetzger
- 1749 Views
Last post by Livens
- 882 Views
- 1843 Views
Last post by FLXC90
- 23 Replies
- 4109 Views
Last post by erikv11
