Ok, this is a 1999XC70 - 130k miles - car slipping only in reverse, with or without driveshaft. Ordered a rebuild from volvo (from vin on car) 4speed not 5 speed.
Got new trans, installed, exact same issue, slips in reverse - no issues.
Took to dealer HO CODES from tcu - Nothing - nothing... cleared memory - double checked - no codes.
WHat are the chances of the exact same issue with a rebuild????
1999 xc70 slipping in reverse
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Did you also replace the torque converter?
- rspi
Contact rspi..
No, the torque converter goes between the motor and tranny.
- rspi
Contact rspi..
Someone may want to confirm this but I spoke to someone changing a transmission today and he said that you likely have another bad tranny. He said that torque converters work or don't. They won't slip in reverse and work fine in forward gears.
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
+1. The torque converter spins in the same direction all the time, just like a flywheel would.
Methinks Volvo f***ed up the rebuild.
5 others that came and went
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
sidebar: it takes an upright engine and transmission.
I say, stabilize subframe - replace/restore ALL mounts and pads to eliminate sag.
bavarianstig
- Year and Model: 99 S70 AWD
Update? I'm curious because I also have reverse slipping in my 99 S70 AWD and wondered if transmission/motor mounts could be the cause of the issue.tranmkp wrote:ok, volvo will cover it - all subframe mounts done - lets see what happens
- 6561 Views
Last post by precopster
- 1923 Views
- 406 Views
Last post by yanga001
- 1172 Views
- 531 Views
Last post by Ozark Lee
