94 850turbo wagon slight smell of exhaust inside
JasonO
Year and Model: 2004 v70 2.5T wagon
Post by JasonO »
when i turn on the heat and fan, there is a noticeable exhaust smell inside the car that lasts for up to 10 mins. any ideas how i should diagnosis this issue? has anyone else experienced this?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
JasonO wrote:when i turn on the heat and fan, there is a noticeable exhaust smell inside the car that lasts for up to 10 mins. any ideas how i should diagnosis this issue? has anyone else experienced this?
Are you sure it is not a coolant smell rather than exhaust? The 10 minutes is kind of strange also. Perhaps the olfactory has been desensitized by then?
JasonO
Post by JasonO »
pretty sure its not coolant, thats more of a sweet chocolate smell unless i'm mistaken.
the odour is more similar to exhaust right off the muffler
and yeah perhaps the olfactory does get desensitized after 10 mins...
could this have anything to do with the PCV system?
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
Open the hood and make sure snow/ice have not covered the intake below the center of the windshield. Then check the rubber seal that the hood rests on, it could me messed up and allowing engine air inside. If there is a turbo leak on the exhaust, it will smoke until the exhaust gets hot enough and it all burns up.
Klaus
MoVolvos
Post by MoVolvos »
_
Klausc wrote:
Then check the rubber seal that the hood rests on, it could me messed up and allowing engine air inside... it will smoke until the exhaust gets hot enough and it all burns up.
If it is the Hood Seal why the smell with only the Heater on
Check for smoke from the Dipstick Tube also. See if it is smoking (PCV System).
_
El Cheapo
Year and Model: XC70 1999
Post by El Cheapo »
I had a similar issue with a 99 V70 turbo. The cabin filter was replaced, but the smell did not go away. It turned out the front exhaust pipe had a small leak at the turbo, and the smell was most noticeable when stopped b/c fumes would rise through the engine compartment and into cabin filter vent. I believe it required replacing the gasket at that junction.
JasonO
Post by JasonO »
thanks for replies...i'll check all these and get back with my findings
