07 S60 2.5T. Thermostat assembly replacement
orbya
Year and Model: 2007 S60
Post by orbya »
I just tried to replace my thermostat assembly. I got as far as draining the coolant, removing the timing belt cover, and trying to access the bolts (screws) on the assembly. Everything I've read including the Haynes/chilton's book requires the removal of the aux belt, and the power steering pump. Anybody done this without these steps, ie with a special tool? I've read something regarding a special Ion torx bit or a u joint that might do the job. Thanks in advance.
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
I did this job a few months ago and I did take the belt and pump off, it was super easy to do! You just need a big sized torx to loosen the tensioner(not sure from memory which size)
Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
