Hi MVS,
Doing a cylinder head on my mom inlaws 98 S70 NA (burnt valve). Im putting in the coolant tonight and I found this big leak on the side of the cylinder head. Looks like a bolt or some sort of sensor is missing...anybody know what is supposed to be there? If its a bolt, anyone know the size?
98 S70 Missing Cyl Head Bolt Massize Coolant Leak
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
I may be wrong, but isn't that where the upper motor mount arm should be?
5 others that came and went
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
A plug with seal goes there. They will remove things that are harmed when they vat the head to clean it. The next question is if the machine shop can find the plug.
- Has thanked: 311 times
- Been thanked: 817 times
Yes the hole has threads, just like the plug that screws in there.
EDIT: #27 and 28 in the diagram you posted are the threaded plug and the seal, you guys are talking about the same thing.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I pulled a head recently and that hole did not have a bolt in it. Was the head new?
burnout8488
- Year and Model: 1999 S70 AWD
Is that the "bung" that the PCV coolant hose connects to on 99+ models? (Heats the PCV pipe under the intake manifold, coolant flows from it to the thermostat housing)
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
- Been thanked: 4071 times
Another MVStery solved!!
- 1729 Views
Last post by petermetzger
- 1765 Views
Last post by Livens
- 1355 Views
Last post by vtl
- 1215 Views
Last post by sirdani
- 632 Views
