I have (or someone has) lost the cover to my high beam lights. I would describe it is a cap or kinda of a screw cover you need to remove to change the bulb. I assume the high beam and low beam caps are the same so that should work as well.
I would like the rubber gasket as well.
Thanks.
WTB: Headlight assembly cap/cover
JRL
- Year and Model: Several
- Been thanked: 16 times
If the reflector dropped it's probably broken and you may need a new headlight.
It would help to know what year and model you have and which side are you referring to!
(I have some cheap lights I would sell)
