IPD sale XeMODeX - Experts in Volvo Electronics
MVS-Amazon link helps MVS!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
2005 XC90 Idler Pulley Seized and Melted. New Engine?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
Equipowin
Year and Model: XC90 2005
Post by Equipowin »
I'm hoping someone has seen this before (and can offer a simple solution). I heard a whine about a week ago and suspected a pulley but waited to address it until the weather warmed. Today the noise turned to a squeal for about 15 seconds while I was stopped at a light. I was 10 minutes from home so I figured I'd check it then. 2 miles later the belt snapped and this is what I have.
I'm afraid the melted portion of the lower puller is machined into the block. Can anyone confirm?
kcodyjr
Year and Model: 1997 850 GLT
Been thanked: 2 times
Re: 2005 XC90 Idler Pulley Seized and Melted. New Engine?
Post by kcodyjr »
That certainly looks like a bolt head to me. Any luck turning it?
That aside, you definitely need a head rebuild as well as a timing job now.
1997 850 GLT sedan, 152K and WHOOHOO!
RIP 1996 850 wagon, 201K, hit by a runaway 4-wheeler
RIP 1996 850 GLT sedan 5spd, 260K, rearended someone
RIP 1986 245 boring, 200K, rusted beyond inspectability
RIP 1981 242 turbo 5spd, 300K, serious teenage crash
jimmy57
Been thanked: 276 times
Post by jimmy57 »
That is a V8. No t belt damage. The damaged idler boss is part of the timing chain cover, not the block.
If the bolt comes out then the boss can be filed flat and a spacer sleeve (piece of the correct sized pipe or other material for a spacer) used inside idler and a washer behind to shim pulley out to correct alignment. The pulley does have to be properly aligned or the belt will want to walk off the edge.
Otherwise it is a new cover. $$$$$$$
mhcrra1
Year and Model: 2006 xc90
Post by mhcrra1 »
I know it's been a little while since your post, but I wanted to add my experience which might help others. This winter my '06 XC90 had the EXACT same problem and totally wiped out one of the idler pulleys along with the boss on the timing cover. I panicked!!! After examining it for a while, I decided to attempt a repair...cut the rest of the boss off flush to the timing cover, the threads were still good (they go in deep) then I found a socket that fit perfectly inside the larger (I think a 12 or 13mm 3/8" drive), cut that down to a length just a tad over the idler pulley inner bushing. Installed it with a new metric bolt and it works PERFECTLY!!!! Just my 2 cents that might help someone else.
jimmy57
Post by jimmy57 »
It would be nice to hear from the original guy. I'm curious how it got fixed.
VFLXC90
Year and Model: XC90 V8 2006
Post by VFLXC90 »
Thanks for the repair tip. We will see more of these failures in the future. When the V-8's become older and neglected. These bearings are going to fail. The v-8's will become very affordable in the near future.
08 XC 90 V-8 157,000 Spouse
06 XC 90 V-8 141,000 Daughter
06 XC 90 V-8 234,000 Son
03 V 70 2.5 Non Turbo
clarka1
Year and Model: 2005 XC 90, 2003 S60
Post by clarka1 »
Just pulled off my idler pulley (2005 XC90 V8) and have the same issue - damaged boss. Considering the approach suggested here (using a custom-made bushing rather than a costly engine cover replacement). For those of you with experience at this, how long has this lasted? Dealer warns me that this is only a "temporary fix" (hmm?) I only have 100K on this vehicle, so I'd like to keep it for a while. Would like to know if anyone out there has regretted going this route? Also, should I have a machine shop make the bushing, or do any of you know of any pre-made that I can order, etc? Appreciate any advice! -Al
yoeddy
Year and Model: S60 2.5T 2004
Post by yoeddy »
I heard about this issue with the 4.4L engine and am trying to get ahead of the issue. Purchased new idler pulleys and tensioner unit and would like to know if anyone had the torque specifications for both of these. I have a 2006 XC90 and the repair looks relatively simple from an access perspective, but I don't want to start without the torques. Any help is greatly appreciated!
Thanks,
Chris
Roger_850T
Year and Model: 854T 1995
Been thanked: 15 times
Post by Roger_850T »
yoeddy wrote:I heard about this issue with the 4.4L engine and am trying to get ahead of the issue. Purchased new idler pulleys and tensioner unit and would like to know if anyone had the torque specifications for both of these. I have a 2006 XC90 and the repair looks relatively simple from an access perspective, but I don't want to start without the torques. Any help is greatly appreciated!
Thanks,
Chris
The belt tensioner gets 90Nm.
For the idler rollers, I don't see a specific torque called out. Both have M10 bolts, and the generic torque for an M10 bolt is 50Nm.
One thing to be aware of, if you don't have the procedure: If you look at your new tensioner, it's got a metal cover plate over the spring, approx. 1" x 2". That cover is "special tool 999-7195". It comes with the tensioner. That's what holds the tensioner compressed until you install it. You can probably put a wrench on the old one and compress it enough to slip the belt off, (I did this, just know to take it slowly, like ~20+ seconds of constant tension on the wrench to compress.) Check the wrench size with the new one, I think I used a short 6 point SAE socket that fit, then a LONG extension to get the needed torque easily. Look for the spot that looks like a bolt head on the tensioner bracket. When you put it all back together, you want to leave this special tool on until you're happy with the belt's position, then pop it off and allow the tensioner to expand and tension the belt.
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
yoeddy
Post by yoeddy »
Thank you for the information Roger_850T, I really appreciate it!
Chris
