I have a '99 v70 wagon. 120k miles. Every so often wipers and fan motor (heating/cooling inside the vehicle) will not work at all. You turn off car then turn back on and everything works. Is this a relay issue? If so, which relay should I replace?
Thanks in advance!
1999 v70 wagon Relay
JRL
- Year and Model: Several
- Been thanked: 16 times
One has nothing to do with the other, completely different circuits
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
Both are common enough failure scenarios and needn't be related.
For the wiper issue, the relay is above the driver's left foot. IPD has a replacement that adds adjustable delay wiper function, so if that turns out to not be it, at least you got an upgrade.
For the fan issue, is it MCC or ECC, and does it happen on any fan speed including high?
5 others that came and went
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Possible flaky ignition switch also.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
JRL
You need a new blower and resistor. Install both and be done with that for 100K miles
As for your wipers, I seriously doubt it's the relay
If you need one I have both, stock and somewhere in the pile, an IPD delay relay
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
For those of you mentioning the relay with a variable delay timer function, the cheaper option is the local pick-n-pull yard, find a VW and grab the relay with .99 printed on the top - does the exact same job - Mike
- 4394 Views
Last post by WA-Boater
- 1001 Views
Last post by ProjectS90
- 11 Replies
- 2826 Views
- 14 Replies
- 4943 Views
Last post by wjhandy850
- 1500 Views
Last post by cn90
