I am changing my front O2 sensor. Can I use an Universal one? Where do you recommend I purchase from.
Thanks,
Michelle
Oxygen Sensor
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
all models available. i would go with either bosch or denso front (upstream). you are lucky, for turbo it's much less expensive.
http://www.partsgeek.com/catalog/2006/v ... ensor.html
JDS60R
- Been thanked: 3 times
Michelle,
We see multiple failures and issues with the universal sensor. I suggest a direct fit Bosch bought through the MVS Amazon link . Oxygen sensors should be changed in pairs. If you have an old rear sensor (not accurate) and a new front sensor (accurate) there can be a performance issue. Long gone are the day where only the front sensor is used to control air/fuel mixture. Bosch will tell you that after 100K miles the sensors are just not accurate anymore.
Retired
Just curious, the reason I'm changing the O2 sensor is because when I'm stopped I smell gasoline, mostly in the drivers side.
What's the difference between the front, back, upstream and downstream?
I will be changing the front one.
Thanks everyone,
Michelle
Thanks everyone,
Michelle
JDS60R
Smelling gas has nothing to do with your oxygen sensor. If you can smell gas you have a safety issue (gas leak)that must be addressed immediately as it is a fire hazard.
Retired
- oragex
I too get poor mpg and noticed once a gas smell under hard acceleration. Haven't checked yet, but on list is the evap, leaking injectors and fuel pump hoses.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Little I know, would a failing oxy show up at CEL?
- 1365 Views
Last post by brant
- 22384 Views
Last post by loveMy850
- 822 Views
Last post by olfac87
- 15 Replies
- 2871 Views
Last post by deepsouth
- 13 Replies
- 5335 Views
Last post by puntmeister
