I was driving my car in the rain one day when I tried turning on the rear windshield wiper, and instead of that happening, the radio turned off. Upon later inspection, the cigarette lighter had also stopped working. I checked the fuse box, and the first fuse, which corresponded to these bits, had blown.
I replaced the fuse, and all worked perfectly again for about 4 days. Again I tried turning on the rear windshield wiper (it wasn't raining, I was just testing) and again the fuse blew.
The second time I had a 3rd party cigarette lighter phone charger in, but the first time nothing was in there. Both times the radio was on. I replaced the fuse and all is working fine for now, but I would like to find whatight be causing the problem. I'm guessing that there is something wrong with the wiper, but I don't know what to make of that information.
1992 240 DL Wagon Fuse #1 keeps blowing
Maximum Turtles
- Year and Model: 1992 240 DL Wagon
daveybeee
- Year and Model: 1996 960
Probably a broken wire harness that runs through the tail gate hinge. Open the tail gate and look at the wires that run through channels under each hinge. If you see broken wires, you have your culprit.
Volvo Meister Tech
Maximum Turtles
Thar she blows! Sure enough one of the wires was split wide open, definetly grounding. Thanks for the reply!
Maximum Turtles
Just an update, its been almost a week since the fix, with no fuse blows. That's a lot longer interval than it had been, I'm fairly sure the problem is fixed, thanks a ton!
- 698 Views
Last post by cole015
- 2017 Views
Last post by 90 Beater
- 1384 Views
Last post by SuperHerman
- 2102 Views
Last post by nthnnxn
- 1974 Views
Last post by doublebug
