2001 X/C 70 runs rough when cold no codes
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
_
Purchased car Jan 2012 first winter: Ran fine (so it seemed) but needed to be in S Mode all the time as the E Mode seem to take a bit more peddle effort to motivate the car but ran smooth in either Mode.
2012 Winter: Colder than "Jan. first winter" so car ran sluggish/rough till warmed but seemed to idle ok. Changed plugs and helped but running a 10W-30 instead of the 15W-40 made it improved considerably but not perfectly and still in S Mode.
2013 Winter: Found Altitude Barometric Pressure Sensor was not working when INDY reset the SRS. Cleaned contacts and car ran fine in E Mode for awhile anyways till it got real cold so back to S Mode. Found timing was off when changing the water pump and set to specs. Car never ran better even in a 2 week of mid 20's degree weather. That's consider cold for N-Cal. Starts up strong and drives off smooth (2 Months).
Oil Viscosity
Timing
Plugs
_
Oil Viscosity
Timing
Plugs
_
- 2165 Views
Last post by RickHaleParker
- 1152 Views
Last post by Rocketny
- 2780 Views
Last post by DeadEric
- 533 Views
- 12 Replies
- 4362 Views
Last post by JPM
