2004 s60 steering wheel vibration when cold then ok
Hi. I have a Volvo S60 2.5T, 2004. The problem is when the car is longer (a few hours / night), and especially when it's cold, the first few minutes / km in the range of 90-100 km gently vibrates the steering wheel, and then stops. Nothing changes when braking, accelerating, driving in neutral or turning. Suspension checked. I suspect winter tires Kleber, but for now I have nothing to swap, to see, so in the meantime want to eliminate everything else. Where to find possibly the reasons for such behavior, and maybe this is normal? Which parts can be such temperature sensitive to cause vibration when cold? CV joints, axles, brakes?
jacobharding
- Year and Model: 87 740 T.I.
Change the air (when warm) in them for starters. If the tires were inflated during high humidity then the water will condensate and freeze inside of them during cold weather and throw them off balance until they warm up. You may end up having to remove the tires from the rims to get all the water out.
Yes, it sounds like an urban legend but I have had it happen.
I am not an expert mechanic, but I will attempt any repair. Worst case scenario is I screw it up worse than it was.
87 745 Turbo Intercooler...333k, all original!
96 850 Turbo wagon "totalled - parting out"
94 850 Turbo wagon waiting for tranny
2 94 855's gone
They're all gone now....
2 94 855's gone
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
if axles bolts are tight, I would suspect a small issue with the transmission, until the fluid warms up
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
tires.
It is very common for tires to do this these days. Tires used to do this and tire companies changed some construction and materials and the issue went away. Lately some of the better performing tires once again have cold flat spotting. I put Yokahamas on my R wagon and they cold flat spot when it is below 25C/high 70s F.
JRL
- Year and Model: Several
- Been thanked: 16 times
My vote is for mild flat spotting
This goes away after a few miles
jimmy57
On days below -5C my tires flat spot if I park for an hour. The distance I must go for tires to normalize again is briefer than an overnight park but they still get bumpy.
- 750 Views
Last post by doublebug
- 1222 Views
Last post by WillieEvans
- 908 Views
Last post by lummert
- 844 Views
Last post by rspi
- 1871 Views
Last post by MoVolvos
