2005 S60 Alarm disable
asummers
Year and Model: many
Post by asummers »
Our daughter has a 2005 S60. The alarm has been malfunctioning for a while now. It is finally to the point where you can just barely hear the horn, and the lights still flash when it is activated. And the message screen says that the alarm was activated. Is there a way to disable the alarm system, like maybe pulling a relay of fuse? And, if that was possible, would the keyless entry still work? Or, is there an alarm reset procedure? Thanks.
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
yes, pull 'siren' fuse side panel behind drivers door. it only deactivates the siren.
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
It is fuse F8 of the CEM under the steering wheel.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If that doesn't work, Volvo has software to disable/remove the entire alarm system's electronics out of the car.
You pull the fuse and I don't think the sunroof works, they're tied together
oragex
Post by oragex »
JRL wrote:If that doesn't work, Volvo has software to disable/remove the entire alarm system's electronics out of the car.
I am not aware of the 2005 models, but on the 2003 the fuse only has the sound disabled, everything else works just like when the alarm is on (or off).
DGM
Post by DGM »
The information display may indicate an alarm system malfunction with the fuse removed. If the alarm module isn't replaced the other best alternative is to disable/remove the alarm system as JRL said.
Alarm system 2005.jpg (52.5 KiB) Viewed 20341 times
asummers
Post by asummers »
Thanks for all the info. I plan on replacing the alarm module, just not right now. It also seems easier to remove the fender to take it out, so I am planning on that method. After replacing the alarm and siren will it have to be reprogrammed at a dealership?
DGM
Post by DGM »
asummers wrote:After replacing the alarm and siren will it have to be reprogrammed at a dealership?
The new module needs to be married with the car. Otherwise the system will store an anomaly code. When I replaced mine it worked right away and I noticed the condition only when the car was scanned with Vida-Dice a few months later. It is a simple Vida-Dice command to have it registered. From what I saw it isn't affecting alarm operation.
Here is a procedure on how to replace it;
https://www.matthewsvolvosite.com/forums/vie ... larm+siren
Also you have this youtube video.
As mentioned fuse location is different of what is shown in the video for 2005-07. Also you can use a long nose Vise-Grip to undo the security bolt.
And Tasca has good price;
Volvo Part : 9452709
http://tascaparts.com/parts/2005/Volvo/ ... eid=213668
