Hello there.
Suddenly appeared strange and powerful sound from the back of engine (of Area cylinder 5).
Is my engine died?
There is no fault codes?
1994 850 is Is my engine dead?
- Year and Model: Many Volvos
- Been thanked: 76 times
The sound actually sounds more like a bad clutch or throwout bearing to me. Does this car have a manual transmission or an automatic transmission?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Sounds like starter(bendix) didn't disengaged when you attempted to start the car.It happens sometimes.nissan wrote:...the starter was slipping sometimes. And the new noise started right after I started the car. Is it related?
What should I check? How should I proceed?
My advice is to remove the starter,rebuilt it or replace it.
Do not drive the car or idle it untill you solve this problem because a fire hazard may occure.
One more thing...if starter is ok...the ignition lock may be faulty...but i vote for a bad starter(bendix).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
I hope the teeth on your flywheel have not been stripped by the faulty starter bendix issue.
It does actually sound like it is only just catching the tip of the teeth so fingers crossed.
The starter bendix may only be too dry and need greasing to allow the spring to retract properly.
- 1183 Views
Last post by oragex
- 1653 Views
Last post by Swedeneed
- 1683 Views
Last post by cichy1012
- 11 Replies
- 2658 Views
Last post by mrbrian200
- 21 Replies
- 3292 Views
Last post by Michaeldiaz94520
