1996 850 interference
dondiano
Year and Model: 850 1996
Post by dondiano »
Is the Volvo 5 cylinder engine an "interference" engine, meaning that the valves and pistons will collide if the timing belt breaks? Thanks!
jimmy57
Been thanked: 322 times
Post by jimmy57 »
Yes, readily.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
20v (B5254 & B5204) are interference ...but i heard that 10 valves engines are not.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
That is correct. The 4-Cylinder, 8 valve and the 5-cylinder, 10 valve are non-interference.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
To the original poster: the US spec cars are 20 valve. All of those 5 cylinders are interference engines.
jimmy57
Post by jimmy57 »
I see Pennsylvania in his profile (thank you very much for putting that in) and already weeded out non US-spec engine choices.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I've worked on the 10 valve (B5252S) 5 cylinder engines and they're interference motors; flycuts on pistons means that's the case.
RJYC
Year and Model: '95 Volvo 850
Post by RJYC »
My 850 which engine code of B5252S /401856 stamped on the block has a 10 valves on it, is it possible to upgrade into 20 valves (B5254S) cylinder head and upgrade also the Piston heads for 20 valves?
misha
Post by misha »
Nope...engine management is totally different.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
it is also not possible to swap a turbo-motor into a non-turbo-body. on p80 Volvos what you get is what you've got, no easy way to change that.
1996 855 R,
2010 V70 D5,
