So here's the deal: the kick-panel lights work correctly when the doors are opened and the remote locks work fine, so I know the door sensor is working correctly. That said, the rocker switch for the dome lights seems to have three options (from left to right): Dome lights on, dome lights off, dome lights on. None of those does what I want, which is to switch the dome lights on when the door is opened.
This is driving me mad!
98 V70 GLT (silly) Dome light weirdness
JRL
- Year and Model: Several
- Been thanked: 16 times
You probably need a new/used upper switch assy, they do go bad
JRL
Grab a couple as many are bad
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I've live with the same problem for 2 years now. Thought it was the missing Alarm Module controlling the lights as the footwell and door lights are good but all the upper ones can't be controlled by the doors. What consist of the Upper Switch Assembly? Thanks.JRL wrote:
_
JRL
The entire panel, outer light switches and middle 3 way rocker button
- MoVolvos
Have not dealt with that assembly but is there a circuit board or just rocker switches that can be taken apart and cleaned like the window switches?JRL wrote:
_
JRL
Both
Sometimes you can, sometimes not, but there are many available in JYs for a couple of bucks, it's MUCH easier just swap out
- 1622 Views
Last post by chrism
- 395 Views
Last post by rspi
- 12 Replies
- 2449 Views
- 1420 Views
- 1095 Views
Last post by aewoodhouse
