Hello Guys,
I read the post for replacing brake pads but there was not enough information so I hope someone can help me out.
HOW TO DETERMINE WHAT FRONT BRAKE PADS TO USE:
- I read here that there are 2 different rotor sizes: 316 and 336 mm.
- I also read that Volvo will tell you if you give them your VIN.
"Volvo of Tempe" (Arizona)
- They told me that there are 4 possible options that are based upon the diameter of the Rim that fits over the caliper, as follows: 15", 16", 17" and 17.5 inches.
- They said they get calls from 3rd-party maintenance shops like Firestone, Sears, etc. call them with my question every day.
- They clearly do not want you to DIY or loose business to 3rd party shops.
I also learned on this forum that Akebono pads are excellent ceramic pads that work great, minimize dust and last a long time. I also read that the rotors will not wear down as quickly compared to OEM pads.
QUESTION ABOUT "RIDGE ON ROTORS:
- I have a 1/16" to 1/8" Ridge on my smooth rotors (at the ID and OD part of the rotors) that should be turned yet I am hurting financially so I would like to know if I should just buy OEM thinking that they will drop into the "slot", for lack of a better word.
- Replacing the pads with Akebono pads will "require" that I turn the rotors, correct?
Thank you for your help!
Stephen in Phoneix
2004 XC90 2.5T AWD Front Brake Pads Replacement
daveybeee
- Year and Model: 1996 960
I think what you need to know is overall rotor diameter. The pads will coincide with that. The smallest diameter rotor will have 1 set of pads, and the 2 larger diameter rotors will use the same set of pads.
As far as the rotors go, I would recommend finding the minimum thickness stamped on the rotor in millimeters and measure your actual thickness. if it's very close or under, you would do well to replace them.
Volvo Meister Tech
- 2340 Views
Last post by cork5695
- 2257 Views
Last post by fishingdad101
- 14 Replies
- 3870 Views
Last post by instarx
- 681 Views
- 589 Views
Last post by nyc1836
