1998 v70xc windows
hi, my passenger front window sometimes will not roll up. This just started happening at a hundred twenty eight thousand miles. When it wont roll up, neither the driver side master switch nor the passenger side switch will help it roll up. If I turn the car off, and then started back up, it sometimes rolls up. I am wondering what the problem might be.
- Year and Model: Many Volvos
- Been thanked: 76 times
Chances are it is the master switch failing. When the master switch craps out it also takes away power from the local switch. The master switch is a very common problem on the S/V series cars.
I have been able to buy time - as in weeks, not months, by spraying the switches with contact cleaner using the nozzle tube aimed at the joints between the switches and the faceplate but on the original switches it gets the plastic on the buttons sticky.
If you do replace it, get an original switch. The Doorman and ScanTech replacements are horrible. My dealer actually beats the Switchdoctor.com price if I order it through their website.
- 769 Views
Last post by gianbrecia
- 2435 Views
Last post by jonesg
- 3757 Views
- 614 Views
Last post by BEJinFbk
- 932 Views
Last post by precopster
