Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
1998 V70 No Power at Fuel Pump Connector
ScaleAutoArt
Year and Model: 1998 V70
Post by ScaleAutoArt »
I thought my fuel pump died but I am not getting any power at the connector [black and red].
What should I go back and check?
Has thanked: 145 times
Been thanked: 401 times
Post by erikv11 »
Almost certainly the fuel pump relay, relay #103, has gone out. You can test this idea by jumpering the relay with a paper clip, which should restore power back at the connector.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6 :shock: 135k
gone: '96 NA 850 210k, '98 NA V70 182k, '98 S70 NA 225k
Post by erikv11 »
Check this out, it includes all you need to know and more:
https://www.matthewsvolvosite.com/forums ... hp?t=52252
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
ScaleAutoArt
I have already tried the jumper with a copper wire...no go. Anywhere else I should check...fuses look good.
Year and Model: 2004 V70 2.5T
Been thanked: 176 times
Post by cn90 »
If you jump #15 and #87 with no result, then you need to go upstream of #15.
Review the diagram below (taken from the link I wrote above).
1. Turn key to position II, you should have 12V at #15 socket (at fuel pump relay socket).
If not...
2. Go to Main Relay FI System relay.
There should be 12V at #30.
Jump 30 and 87 at Main Relay FI System relay socket, leave the jumper in 15 and 87 (fuel relay socket).
If car runs, then the Main Relay FI System relay is bad.
3. Lastly, it may be bad ignition switch, the electrical portion of it.
ScaleAutoArt
OK...I have power at the pump when I jump the relay...but not when the relay is in place. But still no life from the pump. Completely dead.
Is it just a coincidence that the relay and pump are dead?????
Need to know before I go and order the parts!
Year and Model: Many Volvos
Been thanked: 59 times
Post by Ozark Lee »
The fuel pump relay has a time delay. It runs the fuel pump for a couple of seconds when the key goes to position II before the engine starts but after the engine is running it is on full time. If you turn the key on to position II and then go back to check the meter it will have timed out if the meter isn't oriented so that you can see it from the driver's seat.
It would be unusual for the fuel pump and the fuel pump relay to fail simultaneously unless the fuel pump relay started to chatter and the fuel pump was on the edge anyway.
Post by erikv11 »
Are you aware that when the relay is in place, when you turn the key to position II power goes to the pump for only a few seconds? So you have to have the meter up there in the driver's seat (e.g.), or have someone else turning the key. If you didn't know that you could be easily fooled into thinking the relay is bad.
EDIT: what Lee said.
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 39 times
Been thanked: 67 times
Post by BEJinFbk »
ScaleAutoArt wrote:OK...I have power at the pump when I jump the relay...but not when the relay is in place. But still no life from the pump. Completely dead.
It could happen. If the pump seized and started to draw
more current than usual, it could affect the relay contacts.
ScaleAutoArt
Ozark Lee wrote:The fuel pump relay has a time delay. It runs the fuel pump for a couple of seconds when the key goes to position II before the engine starts but after the engine is running it is on full time. If you turn the key on to position II and then go back to check the meter it will have timed out if the meter isn't oriented so that you can see it from the driver's seat.
Thanks Lee...got it. Had the Wife turn it on while I was in the back. Got a signal for a few seconds. Relay is good, pump is dead ;)
