98 v70 awd check engine light and other
lowufo777
Year and Model: V 70 awd 1998
Post by lowufo777 »
Hey All
2 small issues
1. where is the switch -sensor for the lift gate .I get a light that the gate is open but it is closed and locked ?
2.I have had a check engine light on for 3 years now (never really found the problem ,think was an evap code,no affect on performance. Is there any fuse /bulb wire I could cut to eliminate the pesky light
Thanks in advance !
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
Im not sure on the lift gate switch.. google it.
As far as the CEL.. I wouldn't cut or remove the bulb its there for a important reason. You need to fix the problem. Do a search on here under evap and you should find some info as far as where to start, more than likely its a broken vac hose causing the problem.
1996 Platinum Edition
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
_
lowufo777 wrote: 1. where is the switch -sensor for the lift gate .I get a light that the gate is open but it is closed and locked ?
The link to the problem may not be the same as yours but check your fuses anyways. I had the truck open warning in the dash on along with the the door chime constantly. Took the lock/latch assembly out and open/cleaned the micro-switch and it did not fix it. It turned out to be a fuse. Can't remember which one so check them all.
Similar problem
https://www.matthewsvolvosite.com/forums ... f=1&t=6906
_
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
Tailgate switch is in the latch.
A shot of WD40 might loosen it up.
Killing the light that's trying to help you is a bad plan.
That CEL throwing a code? There are a ton of folks here
that would be happy to help you turn it off the right way.
Most parts stores will read that CEL code at no charge.
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Plus a dead cel is an automatic fail at inspection time.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
