My mechanic replaced blower motor. It was rush job as he is going on vacation. Blower whines a little and the seat heaters don't work. The lights come on but no heat. Is there a connector that might have been overlooked. Neither the passenger nor the driver's side seat heaters work. It is really cold in Maine.
Thank You For Any Help,
Cindiana
2004 xc70 seat heater not working after blower replacement
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I drive a S60, not sure if it's the same electrical.
The blower is not connected to the heating seats, at least not directly. It has a single electrical plug. Only the glove box light plug is disconnected when the blower is replaced.
I would suggest checking the seat heater fuse in the fuse panel.
Both of those fuses look fine, I switched one out just to check. Isn't there some big fuse under the hood that goes to those? I bought the car used and do not have the manual.
The seat heaters worked fine until the blower replacement. And he had unhooked the battery.
- oragex
I've read about side-issues when hooking back the battery, sometimes with the control panel. I can't help more.. I would unplug the positive cable at the battery for 12h (vernight) to see if it resets anything.
- 1279 Views
Last post by Ozark Lee
- 1539 Views
- 593 Views
Last post by jonesg
- 2833 Views
Last post by NYVolvo1994
- 2485 Views
Last post by Miltown
