The problem is that most of the engines I've found are B6304S. It's 204hp made '99, the previous version of mine engine which is B6294S (200hp) - 2000y.
According to VIDA (and VADIS - double checked) B6304S could be mounted with the same set of gearboxes as B6294S. Mine gearbox is manual M65, so no problems with timings and communication between ECM and TCM are expected, as I don't have TCM at all
Mechanically it looks like the job is doable. Same mounting points, same intake and exhaust manifold are used for both engines. Both have VVT on Intake. The solenoid itself seems to be same part, too.
What makes me suspicious is the famous VVT and it's control by the ECM.
I can deal with VVT setting. I've done it, soi I'll do it again. As I said - mechanically it's all clear for me here. I've done top end rebuilds of 5 and 6 cyl Volvo Modular Engines.
Could I expect any surprises from car's electronics by swapping B6294S ('00) with B6304S ('99)?
Did somebody went though that or similar route?
Help, please.
Thank you.
