IPD sale Volvo Parts
1994 Volvo 850 EGR cleaning
mmd94
Year and Model: 1994 Volvo 850 Base
Post by mmd94 » Fri Mar 07, 2014 1:02 pm
Hello, I was recently replacing my PCV system. upon doing this I noticed A LOT of carbon build up. The EGR being the worst. The ports had no airflow at all, and the build up was hard to break through. Probably gonna be easy to remedy, but I cant seem to remove the pipe from the valve. Can someone help?
Year and Model: Many Volvos
Been thanked: 28 times
United States of America
Re: 1994 Volvo 850 EGR cleaning
Post by Ozark Lee » Fri Mar 07, 2014 1:58 pm
Getting the valve off is always a bear. I have found the path of least resistance to be to remove the valve from the intake manifold by removing the two small bolts (hand cramp alert) that bolt the valve on from below. Once the intake manifold is use long wrenches to loosen the pipe. I'm not so sure I didn't use a big pipe wrench the last time I did it but that was a few years ago.
The main thing to get clean is the hole through the bottom of the intake manifold itself. For the valve, you can usually just use brake cleaner on it while it is in place and get it clean enough.
'99 V70XC - Nautic Blue
rspi
Has thanked: 18 times
Been thanked: 33 times
Post by rspi » Fri Mar 07, 2014 3:02 pm
I have a video on YouTube about it. You can go to YouTube and type in "Volvo 850 EGR Cleaning".
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
Paul-93-850
Year and Model: 1993 850 non-turbo
Post by Paul-93-850 » Wed Jun 13, 2018 5:29 pm
After cleaning how do you know if it is still functional? Is there any kind of test?
lcc014
Year and Model: 855, 1995
Post by lcc014 » Wed Jun 13, 2018 5:47 pm
Vacuum test if you have mightVac to make sure valve inside EGR is still in working condition.
Who is online
Users browsing this forum: bmdubya1198, erikv11, Google [Bot], Jaumme, jeffsws, Kennigel, PeteB and 71 guests
