Alright guys, as the title states I have a 1996 Volvo 850 GLT with an M56 trans. I've had a problem of a rough idles and cutout or the car stalling after it warms up. Sometimes it idles down low enough and makes the oil light come on, but as soon as the rpm's go back up the oil light goes off. I thought it was a fuel related issue and have replaced the fuel pump, fuel pump relay as well as the injector relay; but that did nothing for me as the issue continued and seemed to only get worse. Then I did a tune up replacing the spark plugs, plug wires, distibutor cap, rotor button, air filter, oil filter, oil, fuel filter; but still no luck with resolving this. Questioning the idle air control valve, so I took it off and cleaned it thinking that would help, but seems to only have made it even more worse.
Can anyone help me figure this issue out before I go spending another $500.00 in parts, Any and all help would be greatly appreciated. Thanks...
1996 850 GLT Very Rough Idle
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Does the car have a CEL?
- rspi
Contact rspi..
If the bulb in the CEL works and you have no codes, I guess you should check compression.
- Has thanked: 311 times
- Been thanked: 818 times
Checking compression is always a good idea, but low compression pretty much always throws a code. Be prepared to keep looking for the cause ...
^^^ this.
I'm sure you want to fix this ASAP I don't blame you, but if your description is accurate then it's not compression. Just chasing every idea you will fix it eventually, but it will cost you. Here's my thinking: nine times out of ten (99 out of 100?), bad compression is bad all the time, not just when the car is hot. And stumble due to low compression pretty much *always* gives a misfire code in the offending cylinder. So go for it as it is not so expensive for a gauge and it will serve you for years, "just sayin" though.
If you are sure about vacuum, my next stop would be electrical. As the car gets hot, the resistance of all electrical parts goes up. Check all of the grounds including where they contact at both ends, and check the positive cables from the battery. Both ends.
Hopefully it is the IAC, since you already sprung for a new one. Oh, check the TPS for sure. Keep checking for codes.
- 472 Views
- 78 Replies
- 12293 Views
Last post by PeteB
- 1410 Views
Last post by cuhfs
- 962 Views
Last post by sweedespeed1
- 641 Views
Last post by MrAl
