Radar Detector hard wired install issue
I have a 2004 V70R and a Whistler 3600 radar detector. The radar unit mounts at the front of the car with wiring which needs to run back into the cabin. Does anyone know a safe location through the fire wall to take the wire? The wiring loom for this car runs through a sealed joint through a double metal skin into the cabin so feeding the cable along side is a no go. Being an R the engine compartment is packed so access is limited. Any ideas would be useful
JDS60R
- Been thanked: 3 times
Follow IPD's videos on how to install a boost gauge. It runs through the drivers side fender and through the grommet by the A pillar.
"Hi Lucky" !!!
He runs his under the cowl panel. I like to come through the drivers fender and exit out by the parking light. ( By that plastic panel that covers the evap valve behind drivers headlight ( see hole in fender).
"Hi Lucky" !!!
Retired
- 498 Views
- 1484 Views
Last post by MoVolvos
- 727 Views
Last post by bcole96024
- 923 Views
Last post by Kingcharles
- 212 Views
Last post by CIK7
