My daughter was using my T5R about six months ago and it died. I had it towed home and there it sat, until now. I put in a new battery and cranked it up. No good. I don't hear the fuel pump coming on (had this replaced about 19 months ago with a used one because I was on vacation). I jumped the relay and that didn't work. Checked the fuel rail, no pressure, just a couple of little drips. I bought a new fuel pump, installed it, still nothing! No sound at all. I put the key forward and listen, but nothing. I tried jumping the fuel relay again after the new pump was installed. Still nothing. Still no pressure on the rail. Engine is spinning, but not even a sputter. Would a broken timing belt do this?
Thanks in advance for any help!
1995 850 T5 No start, possible fuel issue??
cudatime71
- Year and Model: 850 T5R 1995
1995 850 T5R Yellow
1993 850
1993 850
I would say check the starter but you said the engine is turning over. Seems like it could be the fuel filter preventing the flow of fuel. When the car runs down low on fuel it clogs the filter faster and it could be at that point. Try blowing through the fuel filter? See if you can feel your breath. Under the back passenger seat on the undercarriage. There may be more issues on top of this. Just one idea
98 Volvo S70 NA 198K - SOLD
02 Volvo S80 T6 150k
cudatime71
I will try that. But I have the fuel pump still exposed in the trunk and I can't hear anything. No hum like it's priming the line.
1995 850 T5R Yellow
1993 850
1993 850
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Did you checked the fuse for the fuel pump...if i remember correctly it should be #2 in the fuse box,but re-check that.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cudatime71
I haven't actually tested the relay, but I did the "bypass with a paperclip" trick, twice. Once before the new fuel pump and once after. I also did check the #2 fuse. The fuse was fine. grrrrrrr.
1995 850 T5R Yellow
1993 850
1993 850
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Are you getting spark? A car needs 5 things to start and run.
1. Fuel
2. Spark
3. Timing
4. Compression
5. Air.
If you are not getting fuel pressure or spark, you likely have a bad cam or crank sensor.
1. Fuel
2. Spark
3. Timing
4. Compression
5. Air.
cudatime71
OK. I pulled the wire that comes out of the coil and sat it next to the opening. It was at night so I was hoping to see a spark jump to it. None! So it looks like I have no spark and I'm sure the fuel pump is not kicking in to prime the line. I am going to research the forum for posts on cam or crank sensor. Any other suggestions are greatly appreciated.
Thanks!
Thanks!
1995 850 T5R Yellow
1993 850
1993 850
I remember when my cam sensor got wet the car wouldnt crank. So I would research that. As robert said it may be spark.
But I beleive you said still no fuel pressure? That's strange
cudatime71
I don't think it's a wet sensor. The car stopped running six months ago and has been sitting ever since. If it got wet, I'm sure it would have dried out by now.
1995 850 T5R Yellow
1993 850
1993 850
- 18 Replies
- 5540 Views
Last post by misha
- 745 Views
Last post by chrism
- 3348 Views
Last post by chrism
- 1683 Views
Last post by Fosgate
- 1032 Views
Last post by polskamafia mjl
