I purchased a set of 18X8.5 Voxx MAGILA GB 73.1 rims and am experiencing vibrations in both the front and rear of the vehicle at speeds 60-65. I had: the balancing checked at two different shops and both stated the center rings were the problems. I contacted both the distributor/supplier and Voxx directly…
Can someone offer a "fix?"
2011 XC60 Wheel Vibration
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Do the wheels have the correct center bore that fits precisely on the hub pilot on the car?
If not then they make wheel locator rings.
If this is the problem the wheel will have radial runout that can be seen with wheels off ground on lift and wheels spun and checked.
Tires can cause this if they have issues. Road force balancer will check for tire issues.
- 1152 Views
Last post by MattyShmatty
- 1524 Views
Last post by Krons
- 9584 Views
Last post by defense49
- 11947 Views
Last post by Cadelane1
- 1422 Views
Last post by JerryG1970
