Anyone had any luck replacing the high pressure hose for the power steering system? I'm worried about fluid leaking onto the timing belt/alternator since the pump is nearby. I suppose I could just cover it with rags/plastic (once cooled). Is it simply a matter of clamping the hose, unscrewing it, putting the new one in, and flushing the system?
I also noticed an oil leak coming from my solenoid. I threw a P0013 code a few weeks ago, but it later turned off. Given the previous code, is it safe to assume I should just replace the whole thing and the gasket?
Any insight appreciated!
2000 S40 leaks everywhere: power steering hose & solenoid
Update: I replaced the solenoid and gasket. Couldn't really tell whether the solenoid was leaking or not, but went ahead and replaced it anyway.
After replacing the gasket on my oil cap, I'm now thinking I may need to replace the breather hose on top of the engine because there was still a small amount of oil leaking toward the middle of the engine block. Fun times.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
If you see leaks around the oil filler cap and breather, you may want to check the condition of the PCV system.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Yeah, I did the "dipstick" test a few weeks ago and it didn't appear to have much suction in or out. At this point, it seems like it'd be better to just replace the whole PCV system than just the breather hose.
- regent
Good thought!
2015 BMW 335i
2015 BMW 335i
- 1562 Views
Last post by Tkollars
- 2970 Views
- 78 Replies
- 12299 Views
Last post by PeteB
- 23 Replies
- 4602 Views
Last post by MadeInJapan
- 933 Views
Last post by beigg
