IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
2006 XC70 Evap Purge valve replacement
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
Has thanked: 9 times
Been thanked: 154 times
Canada
Post by scot850 » Tue Apr 08, 2014 12:35 pm
Ok I'm stumped. From what I have been told, and read, the Evap purge valve (not pump) is attached to the fan shroud on my car. Only valve I can find is the brake booster valve on a bracket attached to the front of the air box. Can anyone enlighten me or post a picture of where it is fitted?
Many thanks,
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Canada
Re: 2006 XC70 Evap Purge valve replacement
Post by scot850 » Tue Apr 08, 2014 12:50 pm
Took a picture of part from FCPeuro web-site and believe I found the position of the valve. It is not on the fan shroud at all. It has a rubber body with a hole in it surrounding the valve, and it just hangs on a hook mounted to the engine block under the intake. The part fitted to that position looks like this:
http://www.fcpeuro.com/products/volvo-e ... vo-8653908
So, I'm assuming either the info posted is wrong (even on FCP's web-site) or 2006 year has it fitted in a different position.
2006 XC70
TRuegg
Year and Model: 2017 S60 Rdesign
Has thanked: 0
Been thanked: 0
United States of America
TRuegg
Post by TRuegg » Thu Apr 17, 2014 12:12 pm
This part must be the most searched for in all Volvo history. I am chasing down an intermittent P0486 (High Pressure Flow) code as well. I have the Evap Purge valve but can't find it on my 2004 XC70. I'm searched all over and can't find a good diagram of where this is. Anyone have a photo or diagram?
Thanks,
TRuegg
Has thanked: 0
Been thanked: 0
TRuegg
Post by TRuegg » Sun Apr 20, 2014 11:23 am
I found it under the engine manifold as above described above here is a photo. Round black in center with hose attached. Hopefully that will help others. This is a 2004 XC70. Replaced valve and old cracked/brittle hoses. Cleared code. Has not returned.
You do not have the required permissions to view the files attached to this post.
