88 245 Low Compression Cyls 3 & 4 + Coolant Leak
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
rgk
Year and Model: Gray 88 245
Has thanked: 1 time
Post by rgk »
Engine making a terrible noise under load, I took it to a mechanic for a quick look who immediately diagnosed a misfire. Checked the spark plugs, looked good. Checked for spark, good.
Checked compression: cylinders 1 & 2 about 150 psi. Compression at cylinders 3 & 4 about 40, causing the engine to limp. Testing the compression, I see that in cylinders 3 and 4 it is low on initial and successive strokes.
No coolant in oil, no oil in coolant. Engine has never overheated. This probably just means a bad head gasket, right? In the seven or so years we've owned the car, we've never had to replace it, and I suspect it's never been replaced.
I noticed coolant weeping between head and block beneath cylinder 4 for weeks before the car started limping. Today I notice coolant weeping beneath cylinders 3 and 4. My guess is that cylinder #4 had a misfire for a while, and that the break in the gasket has spread, causing three and four both to misfire, causing the severe condition.
In all likelihood this is a bad head gasket. But could the low compression be caused by anything else that I can check for?
rgk -- was dickdeadly
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Post by 5ft24 »
It sounds like the head gasket is blown between cylinders 3 and 4. Was the engine pinging before all this started? That can cause damage, including burning the head gasket. I would not drive it anymore so as not to cause any further damage. Definitely need to pull the head and have it checked by a machine shop for straightness and for cracks.
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
Pick up a full headgasket kit - Volvo part number 270689.
FCP also sells an Elring kit for ~$60.
OE Volvo is ~$100 from Tascaparts.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
rgk
Has thanked: 1 time
Post by rgk »
I pulled my head and discovered that it is, unfortunately, cracked between several cylinders. I have found a replacement head and am working on cleaning it before I put it on. I looked at those FCP kits and am very surprised to see how reasonable they are. Will definitely be purchasing from FCP Euro.
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Been thanked: 2 times
Post by difflock54 »
Worth you having a qualified machine shop check over the replacement head before you fit it.
Could be warped and a skim is well worth the expense. They can reseat the valves etc also so it's then good to just refit.
rgk
Has thanked: 1 time
Post by rgk »
Yep, for sure. I just dropped it off at the shop. The old lady wouldn't let me not have it checked. God bless her.
