1994 Volvo 850 Turbo OIL LEAK
Baptiste1106
Year and Model: 850 1994
Been thanked: 2 times
Post by Baptiste1106 »
I have oil leaking from the upper oil cooler, buts it's not leaking from the actual line. It's like its leaking from the piece that connects to the radiator. Should i replace the O rings in the oil cooler line ( upper) or replace the Rad?
Has thanked: 1506 times
Been thanked: 3822 times
I think I would try the rings first, just because it's easy !
If you can get that oil off with solvent, a bead of silicone might stop the oil seep too.
