Hi,
I took my car to a shop and they check the voltage of the A/C relay in the ECM and was reading 3.5 volts and not 12v. They told me that they reset the head unit and the compressor kicked on. It seems that I have a electrical problem steeming from the head unit itself. I notice on my dash, red lights flicker on my a/c panel even when my a/c is off. How often does the actually a/c unit in the dashboard malfuntion in the S70s?
1998 Volvo S70 5CL Non-turbo A/C Electrical ECM
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's certainly not unheard of. It was more common in the early 850's, but there are plenty of things that can go wrong in there.
A junkyard will be your friend. I suspect that the control module from a 1999-2000 is different, so try to find a 1998.
The AC relay behind the glovebox have also been known to go bad on these cars.
'98 S70 T5
2016 Chevy Cruze Premier
