97 850GLT Wagon door stops Topic is solved
GRB
Post by GRB »
Has anyone had any problems with broken door stops at the body, Had it welded a couple of months ago and the welds broke. The body shop says its a fault with the way it was made.
Dave Cook
Post by Dave Cook »
Yes, my driver's door stop broke. I found a replacement but have installed it yet. I think one of the rear doors is headed in the same direction.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Yup, this is common on 850/70s.
steve
Post by steve »
Yeah, my driver's door stop has just pulled free. I'm a bit concerned about welding so close to the loom. I've recently replaced the check strap on the same door.
Sean DeHaven
Post by Sean DeHaven »
matthew1 wrote:Yup, this is common on 850/70s.
Hello -
Is there any documentation on this being a common problem? I have a 98 S70 and the door check weld broke - Dealer wants an arm and a leg to fix it.
Any suggestions?
Thanks -
matthew1
Site Admin
Post by matthew1 »
Depends what you call documentation. My source? Volvo chat boards such as this.
I'd say it falls somewhere between thermostat failure (rare) and turbo oil return line leaks (very common).
If you're thinking about forcing a recall, first check that there isn't one alrady (sounds like you have though). Then start contacting people and get together (like starting a sign-up thread here for those afflicted with this).
