1996 850 2.5 20v Fuel pressure?
Beastu
Year and Model: 850 2.5 20V 96
Post by Beastu »
Hi,
I was wondering if anyone knew the stock fuel pressure on this car, my car is running pretty weird and seems like its not getting enough fuel. But how much fuel pressure is it supposed to have?
Thanks in advance.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
43.5psi after 1st prime without starting the engine,around 35psi with engine idling & again 43.5 psi on full throttle.
Everything around 35psi is acceptable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Beastu
Post by Beastu »
So if its running 43.5 on idle and 51PSI on full throttle it is bad? and this might explain why we think its not getting enough fuel?
misha
Post by misha »
With 51psi you have more pressure.With that pressure the engine will not starve for fuel.
With that pressure,i guess,fuel pump isn't stock.Do you have high performance fuel pump installed?
It's either that or the fuel pressure regulator is stuck,but could also be a clogged fuel filter.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Beastu
Post by Beastu »
As far as i know i dont have a high performance fuel pump... Its not long since i took the ownership of this car and i havent really looked at the fuel pump :P So if the fuel pressure regulator is stuck then the car might be running unsmooth? Its an auto transmission btw(does this affect the fuel pressure?)
misha
Post by misha »
Transmission doesn't affect fuel pressure.
Do you have check engine(lambda) light ON?
Bad Fpr can affect performance,but with that pressure you have ...can't.It would affect if fuel pressure is low.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Beastu
Post by Beastu »
No error codes show up in the dashboard :/ The car is acting like this... When in park it is running relative smooth, but in D(drive) with the brake in its running really unsmooth goes from 700-1100 RPM and shakes. But its running pretty smooth if i start it the morning after. If i try to push the gas pedal all the way inn rapidly the car will shake and have very little power. If i press it slowly in it accelerates at normal speed. It gets worse the more i have driven the car that day.
misha
Post by misha »
I would replace spark plugs,ignition cables and inspect cap & rotor.
Spark plugs only oem Volvo,set of 5,wires Bougicord and cap & rotor only Bosch if they need to be replaced.
I think that those things are making problems.
Does the Lambda light come on on Check when key is in position II?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Beastu
Post by Beastu »
Cant remember seeing the lambada light when in position II, not that i was looking for it... hmmm... gonna check when i am off from work, thanks for help :)
misha
Post by misha »
If not,then it is burnt or removed from the dash.
From your description i realize that the engine is misfiring and ignition parts must be replaced.
Stage "0" must be performed.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
