2004 xc70 clunking after car gets warm
das1997
Year and Model: XC70 2004
Post by das1997 »
First I want to thank everyone on this forum for all the excellent advise posted. I bought a used xc70 2004 couple years ago and love this car. I went from a gmc crew cab and now the wife drives that I and get the car. When I bought the car I heard this clunking after driving it for couple hours. They replaced a upper engine mount and said all ok. I drove it several months going ino the winter and didn't really hear it. As the spring came, so did the noise. They still didn't find anything and I'm too stubborn to keep paying the labor for them to tell me nothing. Drove all summer and learned to live with it. This winter again the noise was barely there. Now warmer weather is here it is bad. It happens only after driving the car awhile, a clunking noise that seems to get louder the longer I drive it. Pull it in the drive, take the kids inside and come back out to shack the hell out of it and nothing. I forgot to mention it only is audible at low speeds like around 20-40. Yesterday in the parking lot waiting for wifey, I played with it. I could start to hear the clunk when I applied the brakes and started back out from a low speed not coming to a stop. I don't hear it when I leave a stop though. And it continues to be heard while driving at low speeds. It's weird why I only hear it after awhile of driving. So I concluded something is getting warm. I read a lot of post here and thought I would try the iPd bushing insert for the subframe bushing.
Does anyone think this should be my first trial expense or should I take it back to the dealer and just pay the labor to see if they can now diag it. I am going to put new rotors and pads on the front as they are starting to vibrate when applied in the last month. Don't think that is the issue, just Maint. (Side note, I replaced the tie rods ends two months ago and thought that was it but the noise did not get noticeable until the weather started to break. Put new ties and an alignment at the same time. )
Thanks for any input
Das
Smytty
Year and Model: 2001 V70 T5
Post by Smytty »
Sorry I don't have a solution for you, but I have the same problem on my 2001 V70 T5. I had it up on jacks today and looked at everything - engine mounts, all suspension components, etc. I couldn't find anything loose or with any play. I think I'll try the subframe mounts too, but I am really interested to see if anyone else has had this problem and fixed it!
das1997
Post by das1997 »
Are you going to try the inserts or replace both bushings? I read that they are hard to replace. Thanks for the reply.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
how is the noise, continuous? like some rotating part that hits once at each rotation?
do you have separate winter/summer tires and wheels?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Control arm bushings or subframe bushing would be my guess.
oragex wrote:how is the noise, continuous? like some rotating part that hits once at each rotation?
This ^ would help to narrow it down.
Also -> Amazon link
das1997
Post by das1997 »
The noise only starts when the car is driven slow and after it warms up. Then it woul resemble a sporadic clinking clunking noise. Not sure if I can but I will try to record it and post. I use the same all weather tires and they have been replaced in November. It weird because I can hear it on our nightly drive around the lake 20-40 speeds but I go get on the interstate and I do not hear it anymore, nor can I get it to make a noise bouncing on the car in the drive right after coming home from hearing it. I will see if I can word it better to help isolate it.
das1997
Post by das1997 »
Sorry it is not continuous. I tried to bounce on the shocks but as soon as it cools down no noise anywhere.
oragex
Post by oragex »
I would inspect the upper shock absorber bearings and torsion bar bushings. What is different when the car warms up is the shock absorbers get softer after driving a while because they are old. They are also softer in warm weather. As for the vibrations when braking, they can be caused by marks on the brake disks but also by worn lower control arm bushings.
Smytty
Post by Smytty »
das1997 wrote:Are you going to try the inserts or replace both bushings? I read that they are hard to replace. Thanks for the reply.
Doing the inserts and upper engine mount first. If that doesn't do the trick, then I'm going to do the lower control arms.
Bartlett S60
Year and Model: 2004 S60
Post by Bartlett S60 »
My S60 made clunking noises. I was sure it was CV joints. Replacing them helped but not completely. My problem was ball joints.
