1998 S70 T5 Towing another car
This topic is in the MVS Volvo Repair Database » Towing a Miata with an S70
TwoVolvoGuy
Year and Model: 1999 V70 GLT
Post by TwoVolvoGuy »
Hey guys. So I will be moving from the NYC area to Nashville for at least a year and I have run into an issue when deciding how to move my cars. I have a Mazda Miata but I can't drive two cars down at the same time. two trips is out of the question and I don't want to pay to move it.
I was thinking about towing the Miata (2250lbs) on a dolly down to Tennessee. I know the max towing the s70 is rated for is 3300lbs but is this realistic? Any and all related input is greatly appreciated.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I don't have experience with this, but if I were going to do this, to reduce drag I'd increase the tire pressure of the rears on the Mazda, to 40 or so?
Has thanked: 1609 times
Been thanked: 4065 times
Your mileage will drop from roughly 30 to 15,mpg in my experience with this
NYC to Nashville roughly 900 miles, so 120 bucks of gas one way solo.
240 bucks gas towing, one way plus dolly rental of 100 USd. Probably still cheaper than uship, but not cheaper than giving it to a college kid for cheap travel.
Don't forget to add weight of dolly to tow rating.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Is the S70 going to be empty or is it going to be full of stuff?
85 GLH, 367 whp
00 Insight, 72 mpg
chexny
Year and Model: 1998 V70r
Post by chexny »
Check the route/regulations. I dont think you can use a dolly on either the NJ Parkway or Turnpike. I think you have to use a flatbed/carrier trailer ie. all 4 wheels have to be off the ground as opposed to 2. That has to add to a significant amount of weight vs a dolly. Frankly you might not be able to have a trailer on the Parkway and have to take the Turnpike.
1988 740 -- Long gone
1998 V70r -- Current daily driver
2004 S60 -- Magically turned into a Toyota Sienna :-)
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Pretty sure no trailers on the Garden State Parkway.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
I have a bunch of posts here about towing a U-Haul trailer 1300 miles with my 850 T5. You can find them in a search.
Also -> Amazon link
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
JimBee wrote:I don't have experience with this, but if I were going to do this, to reduce drag I'd increase the tire pressure of the rears on the Mazda, to 40 or so?
The Miata is RWD; is it wise to have the rears on the ground while towing?
tryingbe
Has thanked: 1 time
Post by tryingbe »
No, you'll have to disconnect the driveshaft.
85 GLH, 367 whp
00 Insight, 72 mpg
TwoVolvoGuy
abscate wrote:Your mileage will drop from roughly 30 to 15,mpg in my experience with this
Just checked, 985 miles :( I don't want to put the miles on the miata. It's my first car, now my weekend and project car. In a way the S70 is my project car in the summer when I drive the Mazda. I don't want to put the miles on either one but the miata cannot tow the Volvo :D .
tryingbe wrote:Is the S70 going to be empty or is it going to be full of stuff?
I will try to limit the stuff in the S70 to just clothes and a laptop or two. The S70 is on it's original suspension however the brakes are all new with good quality parts.
chexny wrote:Check the route/regulations. I dont think you can use a dolly on either the NJ Parkway or Turnpike. I think you have to use a flatbed/carrier trailer ie. all 4 wheels have to be off the ground as opposed to 2. That has to add to a significant amount of weight vs a dolly. Frankly you might not be able to have a trailer on the Parkway and have to take the Turnpike.
I was aware of that and thankfully I only spend 5 miles on the parkway because most of the trip is on 78.
matthew1 wrote:I have a bunch of posts here about towing a U-Haul trailer 1300 miles with my 850 T5. You can find them in a search.
Will look for your posts, thanks Matt.
It's manual, so I would just leave it in neutral and let it roll.
