Hello,
I just changed my headlight bulbs and the passenger side was all lose inside when i was removing the old bulb. The outside glass is fine but the interior of the housing is loose and moves back and forth very easily. Can anyone tell me how i can fix this? I don't want to start taking everything apart if there is an easy fix.
Thank you,
Derek
1997 850R - Loose headlight housing
Mikesvagen
- Year and Model: 1994 Volvo 850t Wago
There are vertical and horizontal adjustment pins basically a ball and a socket. When you install the head light make sure they are both seated properly. one is almost dead center top the other will be at the lower inside corner (closest to grill) either they are not seated or one has broken.
1994 Volvo 855 Turbo 1997 Volvo 855 T5 1996 Volvo 854 T5
- Year and Model: Many Volvos
- Been thanked: 76 times
Be sure not to touch the reflective surface in the process. The reflector is easily damaged by even the slightest touch.
How do I actually reattach this? I assume since you are saying not to touch the reflective surface that i need to take the lens off? I guess I can just pull the whole assy out and figure it out. I wanted to make it as easy as possible.
1997 854R
IPD Intake
Ported/Polished Intake Manifold w/3" Throttle Body
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
IPD Intake
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
remove the headlights.
Remove both back covers from the headlights. You'll see where the adjuster is and where it isn't hooked up inside. Turn the external adjuster to the correct position to get the ball into the socket again. I've had to do this with 3 different cars.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
That doesn't sound all that bad. I will get working on it soon!
Thank you all for your help!
1997 854R
IPD Intake
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
IPD Intake
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
- 1529 Views
Last post by alschnertz
- 1505 Views
Last post by t1adler
- 1602 Views
Last post by sidpink
- 19 Replies
- 4123 Views
Last post by speedyt5
- 5134 Views
Last post by AVOIT17
