Link to my tracking page: http://forums.swedespeed.com/showthread.php?t=165815
Year/Make/Model: 2007 Volvo S60R
Color: Black Sapphire / Gobi
Transmission: 6 Speed Automatic
-Car will come with various modifications & upgrades, including:
-IPD "Stage II" tune
-Forge CBV
-IPD Track Spec Sway Bars
-TME Springs
-EST Ceramic coated down pipe
-CX Racing FMIC
-Snabb 3" Turbo Intake Pipe
-IPD Poly subframe inserts
-Hawk HPS Pads
-Adams Rotors Dimpled Rotors
-IPD Poly Upper Engine Mount
-Red Painted Calipers w/ Brembo logo
-DRL delete
-Amber deleted from headlights
-IPD "R" Door Pins & Bezels
-Adjustable Rear Toe Rods
-IPD Rear Camber Adjustment Bushings
-TKI Powergrid Street End Links
-DEM Cover
-Poly Lower Transmission Mounts
-Silicone Lines
-35% tint all around
-IPD HD Ignition Coils
-Alpine UTE-42BT single DIN head unit with bluetooth
-Just passed NY inspection last week
-Boost is very stable. Dyno results were 285awhp/305ft-lbs torque. Using data logger, boost stayed at 17.5 psi the whole pull. Can provide graphs if desired
-New Volvo engine at 68k miles, serpentine belt also replaced at this time. This included new plugs, PCV, everything and was covered by Volvo under warranty
-Oil changes every 5k miles with Castrol 0w-30
-Struts/shocks replaced at 65k miles with new Monroe 4C OEM
-Transmission Fluid flushed at 60k, 95k
-Professional Stage I paint correction just performed this week. The paint is now near flawless and has a hydro coating applied
-Comes with 5 Ronal R41 wheels, 2 have slight bends. The one that is currently mounted is fine for now and no air leaks from tire
-Michelin Pilot Super Sports 235/40r18, they have another season or 2 left on them
-Fresh alignment will be performed
-All maintenance done on time. The car was meticulously taken of. Too much to list here. All fluids are fresh, including coolant, brake, drivetrain. Here is a highlight on some of the more major items:
-Right before I received the car at 23k miles, the angle gear was replaced under warranty
-Fuel Pump, PEM, Fuel Level Sender replaced at 55k miles
-XC90 axle bolts installed at 70k
-Brake fluid flushed with ATE Super Blue last year
-Angle gear, haldex, rear diff flushed at 75k, no leaks or seeping
-Starter replaced under warranty at 79k
The car has had body work done, but no major accidents. There were 2 instances
1. The car had an egg thrown at it (bastards!) on the rear driver side quarter panel. The whole panel and part of the door was repainted by a professional shop
2. I hit the corner of the wood wall in my driveway while turning and put a small crease in the rear passenger side door and quarter panel. The crease was pulled and the quarter panel and part of the door was repainted by a professional shop
Anything that has gone wrong with the car has been promptly dealt with and there are no nagging issues.
More pictures can be found below.
Asking $14,000
-Patrick
Please PM with inquiries.
Carfax is clean, available if requested.
