2001 s80 t6 no acceleration
ok so i was the one with the problem where i changed the pcv box and a few days later i lost all acceleration beyond 1400 rpm anyways i changed all vacuum lines and checked all hoses still nothing so i took it to a volvo mechanic he checked it with the volvo diag software and found nothing still no check engine or warnings or codes so he kept it for awhile checked the etm its fine checked the turbos there fine did a boost pressure test everything there is fine now hes checking the fuel pressure but so far hes at a loss as well as i am what is going on?
Oly_850
- Year and Model: 2000 S80 T6
Sounds like a significant vacuum leak on the intake side, check the Intercooler hose fittings all the way to the ETM, that thing is introducing air past the MAF or you have weak or irregular fuel pressure.
'12 Ford Focus SE - Black Pearl
Owned:
'00 Volvo S80 T6 - Maroon
'98 Volvo V70 - Red
'90 Volvo 740 GLE - (sold, too far gone)
'96 Volvo 850 GLT - (totaled) :\
Want - A6 Quattro, XC90, C303
Owned:
'98 Volvo V70 - Red
Geoff_in_Darwin
- Year and Model: S80 2001
Even though it checked OK, still sounds like limp home mode from ETM. We had intermittent ETM issues on S80 & S60, both at about 80-100,000 km, (50,000 -62,500 miles. in each case Xemodex exchange fixed issue. On the S60, after fitting needed computer reset on VADIS.
- 15 Replies
- 7227 Views
Last post by WarbirdPilot91
- 551 Views
Last post by frknvgn
- 1027 Views
Last post by Jackazz
- 1467 Views
Last post by mrmikestl
- 751 Views
Last post by Synergychaz
