IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
1996 850 Wagon Service Light On Topic is solved
Year and Model: 850, S/V70, 06 S60R
Has thanked: 103 times
Been thanked: 312 times
United States of America
Re: 1996 850 Wagon Service Light On
Post by erikv11 » Sat Oct 05, 2019 6:52 pm
Did you strip down the wire, clean it up well, fresh cut etc? Just dumping in solder may not fix things. Well I suppose the thing to do there is just check if it is still heating up.
These users thanked the author erikv11 for the post:
PeteB
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
gone: '96 NA 850 210k, '98 NA V70 182k
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 361 times
Been thanked: 1108 times
Trinidad & Tobago
Post by abscate » Sun Oct 06, 2019 4:55 am
It would be interesting to gather a set of reading in Volvo P80 battery cable temps with conditions for diagnosis, my favorite disease.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 26 times
Been thanked: 3 times
PeteB
Post by PeteB » Sun Oct 06, 2019 6:55 am
I cleaned what I could get at really well, used non-acid flux and our 320W (this is huge wattage)
soldering gun and it worked pretty well. We also did the pos and neg smaller wire bundles that are crimped.
Terminal is cold now.
It would be great to know all of the connections that typically go bad due to oxidation.
Our older version is a bit more powerful than this:
https://www.zoro.com/weller-solder-gun- ... gLa1PD_BwE
Walmart battery is no longer cheap at about $100, anyone know of a decent cheaper battery?
PeteB
PeteB
Post by PeteB » Mon Oct 07, 2019 10:55 am
I'm thinking that when the battery is so dead that it won't open the locks it needs more than
a half our ride to work to charge it.
Problem seems to be intermittent, when I tested it everything seemed fine, other times
there seems to be a drain that kills the battery over night.
Is there anything that's triggered on a light sensor for day vs. night?
PeteB
PeteB
Post by PeteB » Tue Oct 08, 2019 9:40 am
We noticed the red lights built into the doors that go on when they are
opened for oncoming traffic to see, wondering if one is intermittently
stuck on, especially since the doors were hit hard in the accident.
The problem is that then I put an amp meter in there I get nearly zero
drain indicating that whatever the problem is, it is not happening.
Charged it overnight on a 6A old Sears charger and the battery voltage
is now 13.5 no load, no charger, not running. I looked up that 12.7 is
full charge, hmm that's very high! Even with a door open and the light
on it is 13.3.V.
PeteB
PeteB
Post by PeteB » Tue Oct 08, 2019 6:33 pm
I found that the big red alternator wire goes to the starter post and back to the
battery through the very large starter wire. This would explain the crimp getting
hot when the battery was completely dead since the charge current would be
very high.
I will get out my bench Fluke meter that will read ohms to two decimal
places and see if soldering the crimp helped to lower the resistance.
PeteB
PeteB
Post by PeteB » Wed Oct 09, 2019 11:59 am
The Fluke meter reads to 3 decimal places on low 2 ohms full scale. It is difficult to
zero but got it within .002 of zero and there was really no difference across the crimp,
or from the terminal to the battery post. Looks good, there could of course be some
non-linear resistance, but who knows.
PeteB
PeteB
Post by PeteB » Wed Oct 09, 2019 3:52 pm
OK obviously there has to be some draw for the radio memory etc. and of course the
fuse for amps in the meter was blown. This often happens when you leave the leads
in the amp spot and try to read a voltage. Replaced the fuse and am now getting
500 to 800 mA or over half an amp which is not right.
I removed the nut holding down the smaller wires on the positive terminal and
measured zero to the small wire and the same 500+ on the larger red wire bundle.
The large main wire alone measured some draw but dropped to zero so there is
probably a cap in the voltage regulator.
Have to start pulling fuses in the car to find the draw.
PeteB
PeteB
Post by PeteB » Thu Oct 10, 2019 6:31 am
Next question is which circuits are live when the key is off/out of the ignition?
PeteB
PeteB
Post by PeteB » Thu Oct 10, 2019 7:24 am
Today the leakage is around 250 to 350 mA.
Pulled every fuse in the engine compartment fuse block and none of them fixed it.
Some made it jump up actually!
Putting those back in and giving it time it came back to 250 -350 mA.
Open to suggestions.
Tempted to snip one at a time the bundle at the pos battery terminal to find which one it is.
Found this post with links to wiring diagrams but none for 1996 using 1995 for now:
viewtopic.php?f=1&t=86511
