2000 V70 SE (Non-turbo) 160K. Daughter was driving home from work when most of the dash warning lights came on: ABS, Brake, CEL, ETS and the "Arrow UP" began flashing. At the same time, the info center (for lack of the correct term) where mileage, miles to empty, etc. are displayed, suddenly went to all dashed lined. Tach ran up to 3500 and car felt like it was not in gear at. Shortly after, it kicked into gear and limped the final quarter mile home.
We pulled the negative battery cable, to reset it. Now the warning lights are off except the Arrow up, which is still flashing.
I'm thinking Transmission Control Module (TCM). Thoughts?
If it is the TCM, can I visit my favorite junkyard and pull one from a donor V70? Are there substitutions? S80? S60? 850?
Thanks as always.
az in SC
2000 V70 Automatic Trans Would Not Engage
allenzachary
- Year and Model: 2006 XC70
allenzachary
2006 XC70, 2002 XC70
I'm not an expert on Autos but we get very few TCM or ECM failures diagnosed on these cars.
When a simple component breaks on these cars, the closed loop systems go haywire and leave you in "limp " mode which seems catastrophic but in fact is designed to just get you home.
Sometimes it is as simple as a vacuum hose that has come off.
precopster
- Year and Model: Lots
- Been thanked: 128 times
I drive the same car with just over 301, 000kms. At those miles I'd be suspecting either a corroded cable (positive to alternator) or bad earth or a failed regulator.
As abscate mentioned the computers are one of the least likely items to fail.
Having the car read via OBDii is a step in the right direction to analysis of the problem. The Torque App on my phone coupled with a bluetooth ELM327 reads it quite well. These Denso cars (engine computer is Denso as are many engine sensors) have very few sensor problems.
The way to have a code change status from pending to stored is to start and run the car with no faulty components for 3 times. Then the arrow should disappear.
- 17 Replies
- 5648 Views
Last post by aaron1611
- 574 Views
- 811 Views
Last post by skippy
- 1334 Views
Last post by RickHaleParker
- 1632 Views
