S70 shudder under braking
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Having a small issue with my new to me 98 S70. It its exhibitng a noticable shudder under braking at about 70-100km/hr but not at slower speeds. I pulled the front wheels today and checked the front end over. The brakes are relatively new (rotors and pads) and appear in good shape. The struts were replaced at some point and the strut mounts too and appear to be in good shape. The only thing I noticed was a very small amount of play in the control arm inner bushings but none on the ball joint end. Could this be the cause or should I be looking for something else?
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
Could you provide a bit more of a description of where you feel this shudder. I know you said the rotors were relatively new, but does this feel like warped rotors or can you feel it more in the steering?
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
shegarty
To me it doesn't feel like warped rotors and there is no pulsating of the brake pedal. When I have experienced warped rotors before there was a noticeable pulsation of the pedal at almost any speed. You can feel it in the steering but it feels more like it is it coming from the frame.
shegarty
I would think that balance would be an issue if the vibration was happening while cruising. This shudder is only present while braking when the car has significant momentum.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Possibly built up crap on rotors. Was the car sitting for a time before you bought it? You may just need to make a few hard stops from high speed to burn off any residue on the rotors. Run you finger over the rotors (cold please) and feel for any rough spots. Look too for any blueish spots on the rotor indicating overheated at some point. If you find that only new rotors can fix that condition so don't bother turning.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- 2338 Views
Last post by HawleyTronics
- 38 Replies
- 6960 Views
Last post by jamadams11
- 1491 Views
Last post by ferocity02
- 854 Views
Last post by jcdillin
- 1336 Views
