Hey members,
i got stumble on this fault, i have vida subscription and trying to replace CEM, now i fixed the new cem and the whole dash light was not coming on, now i log in to vida and get in the vin and purchase reload file, and the file i got is 9438273, i want to know if this i loaded into the cem is the right type, the vin for the car is YV4CZ982481434082
because i keep getting Cem-6c48 - transponder type signal faulty,
because of this i have perform several reflash or reload of same 9438273 but yet still car wont start and fault code exact, finally i have taken off the remote from the key and i am planning to reprogram the key alone with it ID that is " ignition key appl ' will this work, i will be glad if someone can give me as well the ignition key appl,
remember tje key in question was starting the car before with the old cem. thank you
2008 Xc90GGD - CEM replacement - CEM-6C48 code
precopster
- Year and Model: Lots
- Been thanked: 128 times
The transponder codes may have somehow been lost. Consult with doublebug or Yagger here on the forum and they can help.
Doublebug has helped me to reload lost transponder codes on both CEM and ECM a couple of times.
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
forumoto, if you have a DiCE, I can check online what happened with your car, after get more info about it I can say you some advices I think.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- 7365 Views
Last post by RickHaleParker
- 10554 Views
- 27 Replies
- 32291 Views
Last post by cn90
- 12465 Views
Last post by jonesg
- 9988 Views
