1999 V70 T5 ignition switch pinout 9447804
aharres
Year and Model: 1999 V70 T5
Post by aharres »
Hello. I replaced the ignition switch on my vo, but when I was reattaching the wiring harness (I mistakenly removed the black plastic cover from the harness) and all of the pins popped out of the plastic retainer... :c
This is the switch I replaced.
http://www.fcpeuro.com/products/volvo-i ... 90-9447804
And in this thread, someone posted a diagram which was similar, but some wires have different colors. It seems the OP also had different wires than the diagram, but he did not say where he plugged his wires in.
https://www.matthewsvolvosite.com/forums ... =1&t=59877
Here is a picture of my switch. I have attached the wires according to the diagram except for the wires I don't have. My wires are: blue-yellow, red, green-yellow, purple-yellow, white-yellow, and regular yellow.
If anyone has better information or even a picture of their pinout, that would be greatly appreciated!
aharres
Post by aharres »
I have found the solution by using the manual posted in the thread matching the wires I have. However, it does not include a yellow/white wire which is the only one left. I consulted my haynes manual which showed the yellow/white wire connected to pin 50.
Here is my wiring diagram.
blue-yellow > 15I
red > 30
green-yellow > 15A
purple-yellow > X
white-yellow > 50
yellow > S
I hope this helps someone. And remember, always take pictures before taking stuff apart!
NSFWaldo
Year and Model: 2000 V70
Post by NSFWaldo »
Does anyone know what the colors correspond to? ie 12v constant, accessory, and full on etc? Any help is great!
I don't understand vests... is it winter on your torso and summer on your arms??
- Mr. Lockwood
Has thanked: 1609 times
Been thanked: 4064 times
The terminal numbers 15, 30,X, etc above are actually industry standards and should be googlable.
It's DIN 72552 if you are an ISOphile.
For instance, terminal 30 Is a direct feed from the battery positive terminal, and so on.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I think this was the help Steve was looking for, for me. Found by cross-reference from another forum -- forgive me father for I have sinned . . . (And I'm not even Catholic, probably makes it 2x as bad.)
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
I did not find this one searching 'ignition switch pinout'
We are truly in the sea of data age
I will add pics of Evita switch to this thread , applicable to part xxxxxx
Bump for the spinner
