how do I remove the rear bumper cover of 2000 S80
james
Post by james »
I've drilled out the inner fender rivets. How do I remove the cover? Something is still retaining it. Thanks
ek
Post by ek »
You still have 4 bolts to remove. Acess the battery area in the trunk. On the back panel, possibly under small foam covers, you will find 4 13mm nuts to remove. you will have to remove the battery to get one I believe. If the rivits are out, just slide it back. One more thing, do not forget to remove the connector on the rightside for the FM antenna. You will have to lower the panel on the right side (the panel to get to the taillights) to access this connector. I hope this helps.
