Hi
last week was driving and my battery light came on volvo s60 2001 2.4t . managed to get it home . charged my battery and restarted the car battery and light was on . tested battery with multi meter with ignition off reading 12.76 aprox . with engine running it was 11 volts aprox . after starting the car a few times on and off the battery ends up flat in need of a charge .also for the last month i have to drive with my traction control switched off as the car thinks i am loosing grip and reduces my power while driving .sensors look ok the wires etc. current error messages are el power system . abs break STOP !
today i have removed the alternator regulator to check the brushes and they look ok a good length on them . is it possible for the regulator to be bad even though the brushes with 10mm on them look fine ?
any suggestions ?
Thanks
2001 s60 2.4t battery light on regulator problem ?
coflynn
- Year and Model: 2002 S60 AWD
- Been thanked: 6 times
Yes - also had my regulator die on my car (2002 S60), which otherwise looked fine and ever passed charging tests. But when it's switched off it would have a huge drain on the battery... just replace it and in the worst case you've got one less thing to fail in the future
cheers . will try and replace it with one or two from local auto scrap yard just to see . hopefully i do not get two dud ones ahaha. could i replace it with one from a newer volvo than 2001 ?
i cleaned everything connection points etc and put it all back together. charged the battery and started the car no battery light on or any warnings . i put the multimeter on the battery while the engine was running and was getting a reading of 13/14 volts. but every 20 sec or so the voltage would go up to 16 volts . when at 16 volts i can hear the fuel pump noise change slightly and also the engine noise changes almost like its struggling to keep running . but it never cuts out . it only does that while at 16 volts. at 13.14 volts it runs normal .
precopster
- Year and Model: Lots
- Been thanked: 128 times
Regulators up to and including 2004 are OK for your car. Best change it before it fries engine or other computers.
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
And headlight bulbs.
cheers guys going to get one from scrappy today to try it . will post outcome ...
EDIT ended up buying a new one fitting and charging battery . hopefully its fixed
fitted brand new regulator and my battery light is no longer on . everything seems to be ok lights nice and bright . the multi meter i was using was giving me wrong readings. traction control still activates at 20mph and has to be switched off to continue driving ?
rjS60Turbo
- Has thanked: 1 time
My batt light is now on SINCE a new starter was installed by dealer. Also, one fog light died since then too AND the AC flutters. Regulator?
- 558 Views
Last post by creekybird
- 12 Replies
- 4111 Views
Last post by br0dy519
- 4358 Views
Last post by redc70
- 3809 Views
Last post by Sebefus
- 4226 Views
Last post by Westsidelewis
