'98 V70 GLT Ticking
Was out driving this evening. Decided I hadn't really opened it up in a while. Mash the pedal and as soon as the boost built up it started missing. Pulled into my driveway a minute later and noticed the I now have a ticking. Not quite a knock like a spun bearing but what sounds like some one tapping a screwdriver against metal. It matches my RPM and doesn't seem to flutter. Dead lifter? Ideas?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Is it still missing? Do you have a CEL? You might have a burnt valve.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Bent connecting rod, piston skirt rattle.
If it is too fast for lifter rattle then this is a real possibility. Lifter rattle is once every two crank revolutions.
Did it run REALLY good just prior to the misfiring like symptoms?
Bent rod caused piston skirt rattle will sound out louder behind and below exhaust manifold.
- Has thanked: 1613 times
- Been thanked: 4078 times
Ugh. Are you at stock boost or have you been playing
- 14 Replies
- 1259 Views
Last post by hotdog067
- 1945 Views
Last post by vtl
- 1167 Views
Last post by sleddriver
- 23 Replies
- 3874 Views
Last post by Blacklab467
- 1689 Views
Last post by polskamafia mjl
