My '07 S60 AWD shows a fault code "Tire Pressure System" and a flashing tire symbol on an intermittent basis. It mostly happens when driving on the highway and clears after the engine is shut off once or twice. The fault is for the TPMS system, not the tires, but I checked the tire pressure and its fine (including the "spare"). Anyone have any idea of the problem. I was told by a non-Volvo mechanic that the battery or batteries in one or more of the tires may be going bad, but as the system clears itself I don't know how a battery could be the problem.
Thanks
'07 S60 Itermittent TPMS Priblem
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
WHen you drive down the road the system is active 100%. WHen you slow down and stop the sensor goes off and a weak battery can recover a bit.
Your symptoms are common for TPMS sensors failing.
If you go somewhere with a tester that activates sensor to give readouts often getting readout repeatedly will let you see a sensor that fails after 3rd readout.
How many miles on car? time above 8 mph or so is the determinant of battery life in addition to calendar.
- 1360 Views
Last post by Georgeandkira
- 13 Replies
- 8047 Views
Last post by dikidera
- 12 Replies
- 1106 Views
Last post by MoVolvos
- 355 Views
Last post by jonesg
- 961 Views
Last post by mlanctot
