Wheels and tires: '99->'98 swap?
ecberr
Year and Model: v70 xc 1999
Post by ecberr »
Hello,
Anybody know if the rims and tires from my 99 v70xc would fit my 98 v70 base? How about the brakes? Thanks
Ed
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Wheels, yes. Brakes, probably. It should be a simple brake swap. One year* Volvo went to 302mm brakes, but I'm pretty sure both these cars were still 280mm. You can just measure the rotors on both. If they're the same, swap away. If not, you can still swap, you'll just have to swap wheels with brakes. Make sense?
* this also might be model-dependent, meaning only R and C70 had the big brakes. I'm too lazy to look it up.
Also -> Amazon link
ecberr
Post by ecberr »
Thanks matthew1. Its inspection time for the 98 and the xc is sitting with a blown motor. Ill give it a try when I have the time and post the results.
thanks again
Ed
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
matthew1 wrote: * this also might be model-dependent, meaning only R and C70 had the big brakes. I'm too lazy to look it up.
pretty sure it's not all of them. i believe it was an option on 98+ T5s, infrequently purchased.
Has thanked: 1611 times
Been thanked: 4075 times
The 99 model year had two brake sizes according to the parts guys, with my T5 having the larger ones
ecberr
Post by ecberr »
I wonder if my xc has the bigns. Hopefully I have time to find out soon. How about abs module?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
ABS is changed from 99 model year.
